Creating a drape surface
Command
Path
Create Drape Surface
Model > 3D Power Pack
You can automatically create a rectangular, draped NURBS surface over an object, up to a specific Z plane value. This is useful for representing surfaces including curtains, tablecloths, product packaging, and (with Vectorworks Architect or Landmark) site models.
To create a drape surface:
Select one or more objects to be draped.
Select the command.
The Create Drape Surface dialog box opens.
Parameter
Description
Number of Points
Specifies the number of control points on the drape surface; the greater the number of points, the closer the drape surface is to the object
U Direction
Enter the number of points to create in the U direction; this number must be greater than 3
V Direction
Enter the number of points to create in the V direction; this number must be greater than 3
Plane Z Value
Specify the base level of the drape surface (how far down the bottom of the drape goes), which must be lower than the highest Z coordinate of the object
Creating a loft surface
Creating surfaces from curves
Creating a fillet surface
Creating planar caps
Creating a NURBS surface by revolving a profile along a rail
NURBS surface properties
Concept: NURBS curves and surfaces
